account
translation
Bricsys Help Center
ATTDIA system variable
Attribute dialog
Shows a dialog box for attribute values for the INSERT command.
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Don’t use dialog box
On (1): Use dialog box
Related commands
  • INSERT command
  • -INSERT command
Related information
  • Defining attributes
  • Inserting blocks
  • Inserting blocks with attributes
  • Working with attributes
© 2025 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
