ATTFULLUPDATE system variable
Reset attributes after editing the block record
Defines the behavior when modifying the attributes of parametric blocks.
If on, the attributes in the associated block references are synchronized.
That is, their parameters, such as rotation angle, position, height of the font, etc. (except the text values), are set according with those of the attribute definitions. Additionally, the missing attributes are restored, and those that have no definitions are removed.
If off, nothing is done. Later, you can manually synchronize the attributes by running the ATTSYNC command.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Nothing is done. On (1): The attributes of all the block references associated with the modified block record are synchronized. |
