BEDITMODE system variable
Block editor mode (Read Only)
The Block Editor can be opened to edit standard static and dynamic blocks or blocks with parametric data (specific to BricsCAD®).
BricsCAD only
Important: Editing of dynamic blocks is possible in Experimental mode except on United States territory. In the event that you purchase BricsCAD® in the U.S. or for use in the U.S., this feature is neither available nor licensed to you. Please see EULA for more information.
| Type: |
Short |
| Saved in: |
Not saved |
| Possible values: |
0: BEDIT not open 1: General (BricsCAD® parametric data is not allowed) 2: Allow BricsCAD® parametric data 3: No restrictions |
