CVALLOWBREAKLINECROSSINGS system variable
Allow breakline crossings
If on, intersections between breakline segments are calculated and added as points to the TIN surface.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Drawing |
| Default value: | 1 |
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Drawing |
