CVARCTESSELLATIONGRADING system variable
Arc approximation mid-ordinate distance
Controls the grading mid-ordinate distance, the maximum distance between the arc and the chord (straight) segment, used for arc approximation.
BricsCAD only
Type:
Real
Saved in:
Drawing
Default value: 0.01
Related commands
  • GRADING command
  • GRADINGBALANCE command
  • GRADINGEDIT command
