DGNIMPXREFIMPORTMODE system variable
External references import mode
Controls DGN attachment import.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: | 0 to 3 |
| Default value: | 2 |
| Possible values: |
0: Omit - does not import DGN attachments 1: Retain - converts attached DGN files to DWG XRefs 2: Merge to cell - converts attached DGN files to DWG blocks 3: Create DGN Underlay - converts attached DGN files to Underlay entities |
