DIMALTF system variable
Alt multiplier
Controls the conversion of alternate units. See also the DIMALT system variable.
Multiples the primary unit to give alternate units. If one drawing unit equals 1 inch and the value is set to 25.4, alternate linear dimensions are expressed in mm.
| Type: | Real |
| Saved in: | Drawing |
| Default value: |
25.4 - If MEASUREMENT=0 and INSUNITS=inches 0.0394 - If MEASUREMENT=1 and INSUNITS=milimeters |
