DIMAPOST system variable
Alt units prefix/suffix
Controls the prefix and/or suffix that appears in the alternate dimension text, does not apply to angular dimensions. See also the Drawing Explorer > Dimension Styles(DIMSTYLE command).
Set to '' to turn off, or use the suffix string 'prefix[]suffix'. Insert a single linefeed with '\X' (often when alternate units are active).
Type:
String
Saved in:
Drawing
