DIMSCALE system variable
Dim scale overall
Applies a scale multiplier to dimension variables that specify the size of the components of dimension entities, such as text height, distance or offsets.
Note: It does not affect measured lengths, coordinates, or angles.
| Type: | Real |
| Saved in: | Drawing |
| Range: | 0 or greater |
| Default value: | 1.0 |
