DMRECOGNIZE system variable
Automatic 3D geometry constraints recognition
Automatically constrains geometrical relations between surfaces, when 3D entities are edited or 3D constraints are recalculated.
BricsCAD only
| Type: | Short |
| Saved in: | Drawing |
| Range: |
-1 to 1023 |
| Default value: | 0 |
| Possible options: |
Negative: Switch off automatic 3D geometry constraints recognition 1: Tangent surfaces 2: Coincident planes 4: Parallel planes 8: Perpendicular planes 16: Cylinders perpendicular to planes 32: Coaxial surfaces 64: Cylinders and spheres of equal radius 128: Vertices between 4 or more faces 256: Edges between coincident faces 512: Fix a constrained plane lying in XY/YZ/ZX (compatibility) |
