DYNMODE system variable
Dynamic input mode
Toggles dynamic input features on/off.
Type:
Short
Saved in:
Registry
Range:
-31 to 31
Default value:
3
Possible values:
0: No dynamic input
1: Dynamic input at pointer (not yet supported)
2: Editable dynamic dimensions
4: Tracking dynamic dimensions
8: Nearest entity by UCS X/Y axes dynamic dimensions
16: Nearest entity dynamic dimensions
Note:
  • When DYNMODE is set to a negative value, all dynamic input features are turned off, but the corresponding value is stored.
  • Click Dynamic Input (DYN) on the status bar to toggle the value of the DYNMODE system variable between positive and negative.
