EXPORTPRODUCTSTRUCTURE system variable
Product structure
Controls if a product structure is exported.
Type:
Short
Saved in:
Registry
Range:
0 to 1
Default value:
1
Possible values:
0: No product structure: Exports a flat structure without components in the target document, whether the BricsCAD® document has a product structure or not.
1: Export product structure: Exports the BricsCAD® product structure data (if existing) to the target document.
Note: The option [1] is valid for Pro (or higher) license level. It works as [0] otherwise.
