FONTALT system variable
Alternate font
The substitute font used when a text font cannot be found.
| Type: | String |
| Saved in: | Registry |
| Default value: |
simplex.shx |
Note:
- This system variable specifies the substitute font used when a text font cannot be found.
- If a font is missing and no replacements are defined in the default.fmp or fontalt.fmp files, BricsCAD® uses the simplex.shx, which is set by default by the FONTALT system variable.
- When FONTALT cannot replace the missing font, the operating system tries to substitute it. If the operating system also cannot find a replacement, the text appears as
???. - It is recommended to always use the original font to maintain a consistent visual appearance across different platforms. In addition, it is recommended to choose fonts that support the language in which the text is written.
