HPTRANSPARENCY system variable
Default transparency for new hatches
The default transparency for new hatches, as a percentage.
Values accepted: ByLayer, ByBlock, '.' (use current), 0 (fully opaque), and 90 (maximum transparency).
| Type: |
String |
| Saved in: |
Drawing |
| Default value: |
| Possible values: |
.: Use current ByLayer: Apply the layer’s transparency ByBlock: Apply the block’s transparency 0: Apply no transparency (fully opaque) 1-90: Apply transparency percentage from least (1) to most (90) transparent |
