IMPORTCOLORS system variable
Translate colors
Controls how colors are converted during import.
Type:
Short
Saved in:
Registry
Range:
0 to 2
Default value:
1
Possible options:
0: To RGB
1: To RGB, if there is no matching palette index
2: To nearest palette index
  • If 0: all entity colors will be converted to RGB, regardless of the current palette.
  • If 1: if the entity color is found in the palette, the entity gets an index color. Otherwise, it is given a true color.
  • If 2: for any true color of the imported entity, the nearest match is searched in the palette and this index color is assigned to the entity.
