NEARESTDISTANCE system variable
Nearest Distance
Controls nearest distance dimension between a pair of selected entities. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type: | Short |
Saved in: | Registry |
Range: |
0 to 15 |
Default value: |
1 |
Possible options: |
1: Show nearest distance dimension 2: Show OX aligned nearest distance dimension 4: Show OY aligned nearest distance dimension 8: Show OZ aligned nearest distance dimension |
