PARAMETERCOPYMODE system variable
Parameter copy mode
Controls how constraints and related parameters are copied with the COPY command.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 4 |
| Default value: |
3 |
| Possible values: |
0: Do not copy 2D constraints 1: Replace all expressions with constants 2: Use existing parameters, if parameter is missing replace it with constant 3: Use existing parameters, create new parameter if it is missing 4: Use existing parameters, create new parameter if it is missing or has different value |
