PDFPRCEXPORTPRODUCTSTRUCTUREMODE system variable
PRC Product Structure mode
Specifies whether Product Structure (blocks and block references) is included in the export to a 3D PDF (PRC) file.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
Off
Possible values:
Off (0): Do not export 3D PDF with Product Structure
On (1): Export 3D PDF with Product Structure
