POINTCLOUDCACHEFOLDER system variable
Disk cache folder
The file path(s) used to store point cloud cache files.
Multiple paths are supported. The first one will be used for adding new cached/preprocessed data.
Separate file paths with semicolons (;).
BricsCAD only
Type:
String Standard
Saved in:
Preference
Default value:
C:\Users\%username%\AppData\Roaming\Bricsys\BricsCAD\V24x64\en_US\PointCloudCache\
