PRINTPDFPREVIEW system variable
Print As PDF Preview
Controls if the Print As PDF preview uses the system default PDF viewer or an internal program window.
BricsCAD only
| Type: |
Short |
| Saved in: |
Preference |
| Range: |
0 to 1 |
| Default value: |
1 |
| Possible values: |
0: Use internal window 1: Use external viewer |
