PSOLHEIGHT system variable
Polysolid height
Controls the default height, in drawing units, for the POLYSOLID command.
| Type: |
Real |
| Saved in: |
Drawing |
| Default value: |
4.0 Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 80.0.
