SETBYLAYERMODE system variable
Set by layer mode
Controls which layer properties are applied with the SETBYLAYER command.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 255 |
| Default value: |
255 |
| Possible values: |
0: None 1: Color 2: Linetype 4: Lineweight 8: Material 16: Plot style 32: ByBlock 64: Blocks 128: Transparency |
