SPAADJUSTMODE system variable
Adjust mode
Controls the adjustment mode used for triangle smoothing. Ignored if FACETRES is used.
Adjust mode identifies which facet nodes are to be adjusted (smoothed) to other than their initial grid positions.
Note: Spa is short for Spatial, the maker of ACIS.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
0 to 2 |
| Default value: |
0 |
| Possible values: |
0: None - No changes 1: Non-grid - Move nodes in the center of surrounding nodes to adjust points surrounded by triangles 2: All - Also adjust grid nodes |
