SPACHECKLEVEL system variable
Check level
Check level used in AUDIT and SOLIDEDIT for checking ACIS entities.
Audit is used to repair drawings that are open. The SOLIDEDIT command edits the faces, edges and bodies of 3D solids and 2D regions.
Value 10 is the lowest, used for fast checking. Value 70 is the maximum, used for comprehensive time consuming check.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
0 to 70 |
| Default value: |
10 |
| Possible values: |
0: Basic transformation consistency - basic pointer and fatal topology check 10: Basic geometry check - cellular topology check 20: Data sharing check, face area and loop orientation check, medium check of curved geometry 30: General surface check - check for sliver faces 40: Degenerate spline surface check, compatibility check between surface and pcurve surface, and check that a COEDGE has a partner on a single-sided face 50: Body containment check - compatibility check between pcurve location and (non-tolerant) coedge location 60: Convexity points check 70: Lump and shell containment check - face-face intersection check, and curve parametrization check |
