account
translation
Bricsys Help Center
SPAMINUGRIDLINES system variable
Minimum number of U grid lines
ontrols the minimum number of U grid lines - the minimum number of grid lines generated in the U direction. Ignored if the FACETRES system variable is in use.
Note: Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type:
Long
Saved in:
Preference
Default value:
0
Related commands
  • MODELERPROPERTIES command
  • -MODELERPROPERTIES command
Related variables
  • FACETRES system variable
© 2025 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
