SPASURFACETOL system variable
Surface tolerance
Controls the maximum distance between a facet edge and the true surface. The value is dependent on the model size.
This variable is ignored for output to STL and PDF if the FACETRES system variable is in use.
Note: Spa is short for Spatial, the maker of ACIS.
BricsCAD only
| Type: | Real |
| Saved in: | Preference |
| Default value: |
-1.0 |
