SVGSCALEFACTOR system variable
SVG Scale Factor
Scales the SVG during an export. Dependent files need to be converted separately.
1 Drawing unit = X SVG pixel.
- If set to zero, scales the current view to fit within the page size set with the SVGOUTPUTWIDTH and SVGOUTPUTHEIGHT variables.
- If set to a positive value, SVG page size is calculated automatically to correspond to required scale.
For example, 96dpi / 25.4 = 3.7795 - the corresponding scale factor for the conversion of 1 DWG unit into 1 mm SVG.
BricsCAD only
| Type: | Real |
| Saved in: | Preference |
| Default value: |
0.0 |
