-BIMWINDOWCREATE command
Creates a fully parametric window or opening based on a closed contour.
Creates parametric windows using as profile any entity such as a boundary, a closed polyline or grid.
Note: This command operates at the Command line.
Method
Select a profile (boundary, closed polyline or grid) on a wall to create a window or an opening. For the option wIndow (set as default), also specify a panel type.
The window or opening is created as a parametric block with BIM properties. The component type is BIM Block (for more information about BIM Blocks, see the Using the Library panel article).
Important: BIM Blocks are compatible with BricsCAD® V26 and later. Drawings with BIM Blocks can be opened with older BricsCAD® versions. However, when inserting BIM Blocks in BricsCAD® V25 or older, they lose their BIM data.
Options within the command
- wIndow
- Creates a BIM Window entity. An opening in the solid on which the profile entity lies is created automatically.
- Opening
- Creates an Opening entity in the solid on which the profile entity lies. The opening is created by a solid on the BC_SUBTRACT layer. This layer is frozen by default. Thaw the layer to select the opening.
- Panel type
Single
Double Vertical
Double Horizontal
Triple Vertical
Triple Bottom
Triple Top
Triple Left
Triple Right
Triple Horizontal
