BIMCLASSIFY command
Classifies an entity and gets a name and an internal unique GUID (= globally unique identifier).
Icons:
Method
Select an element type from the listed options or press Enter (Other option) to open the Classify As Bim Element dialog box to display all categories and choose a type (see the Classify As Bim Element dialog box article).
Then select the entities to classify or press Enter (Drawing option) to classify the entire drawing.
Note: The GUID is maintained even when the BIM classification changes.
A classification can be assigned to any DWG entity.
Options within the command
- Wall
- Classifies the selection as walls.
- Column
- Classifies the selection as columns.
- Slab
- Classifies the selection as slabs.
- Beam
- Classifies the selection as beams.
- wIndow
- Classifies the selection as windows.
- Door
- Classifies the selection as doors.
- sPace
Classifies 2D and 3D entities as spaces. (IFC Spatial Structure Element)
Converts BIM rooms to BIM spaces.
- buiLding
- Classifies 3D entities as buildings. (IFC Spatial Structure Element)
- sTory
- Classifies 3D entities as stories. (IFC Spatial Structure Element)
- building Element
- Classifies the selection as unspecified building elements.
- Xref
- Classifies the selection as external references.
- Other
- Allows to classify the selection or convert the selection to a block and classify the block reference.Note: Displays the Classify As Bim Element dialog box.
- Auto
- Automatically classifies the selected entity or entities.Note: This is the same as running the BIMIFY command.
- stRuctural
- Classifies the selection as Building Structure Elements.
- Unclassify
- Removes all BIM data from the selected entities.
