BIMGUID command
Generates new GUIDs or assigns a user-specified GUID.
Method
The command generates new GUIDs for multiple BIM classified entities with non-unique GUIDs or assigns a user-specified GUID to a single selected BIM classified entity.
- To generate new GUIDs for multiple BIM entities at once, select the entities, then press Enter.
- To manually assign a GUID to a BIM entity, select the entity, press Enter, select the Input guid option, and then type the GUID.Note: The string must have 22 characters and be unique.
Options within the command
- Generate
- Generates a GUID for each of the selected BIM entities with non-unique GUIDs.
- Input guid
- Prompts you to enter a GUID for the selected BIM entity.
- Transfer guid
- Copies the source entity GUID to the previously selected entity.
- Regenerate
- Regenerates the GUID of the source entity to ensure unique GUIDs.
- Keep
- Keeps the original GUID of the source entity.
