MEASURE command
Places points or blocks along entities at equally-spaced specified distance.
Icon:
Method
Specify the entity you want to measure and enter a block distance value or insert a block. On the entity the points are places at equally-spaced specified distance.
Note: Points are usually invisible, so use the PdMode variable to make them larger.
Options within the command
Insert block
Inserts a block instead of a point.
Align block
Rotates the blocks to match the entity alignment.
