POINTCLOUDDELETEITEM command
Deletes point cloud files.
Icon:
Opens the Point Cloud Reference Manager dialog box to delete point cloud files from the cache.
Note: It also removes all the insertions (if any) of that point cloud in the current drawing.
  1. Process a new scan
  2. Name
  3. Path
  4. Size
  5. Type
  6. Status
  7. Action area
  8. Total cache used
  9. Current free space
  10. Cache folder settings
Process a new scan
Attaches a point cloud file by launching the POINTCLOUDATTACH command.
Name
Displays the point cloud file name.
Note:
  • The point cloud cache name is a user specified name for the preprocessed point cloud. It's the default point cloud name if you do not specify a point cloud name for insertion.
  • The double-byte characters are accepted for the Point cloud name.
Path
Displays the point cloud file location.
Size
Displays the point cloud file size in MB.
Type
Displays to which type the inserted file has been preprocessed. If the POINTCLOUDHSPC system variable is ON, the file is inserted as an HSPC type.
Status
Displays the point cloud file status:
  • In progress bar: the file is in pre-processing.
  • Ready: available for Insert or Delete.
  • Inserted: the file is inserted in the current drawing.
Action area
Cancel
Allows you to interrupt the preprocessing of the file. Once the point cloud file is preprocessed and ready to use, the Cancel button disappears.
Insert
Opens the Attach Point Cloud dialog box and attaches the point cloud file in the current drawing.
Note: Multiple insertions can have the same or a different point cloud name.
Delete
Removes the point cloud file from the cache.
Total cache used
Specifies the total amount of the used cache.
Current free space
Displays the total amount of available cache.
Opens the Settings dialog box to set the POINTCLOUDCACHEFOLDER system variable value that specifies the folder(s) where point cloud cache files are stored.
