TABLESTYLE command
Opens the Drawing Explorer dialog box with Table Styles selected.
Opens the Drawing Explorer dialog box with Table Styles section selected to view and modify table styles in the current drawing.
Options within the Drawing Explorer
Cell style settings
Defines the cell style settings for each cell style: Title, Header, and Data. Click the drop-down list and choose a cell style.
Text Style
Sets the Color, Style and Height for the selected cell style.
Cell Margin
Defines the spacing between the cell border and the content of the cell.
Horizontal
Specifies the distance between the cell content and the vertical cell borders.
Vertical
Specifies the distance between the cell content and the horizontal cell borders.
Display
Defines the background color and the text alignment.
Background color
Specifies background color This can be done from the drop-down list or through the Color dialog box.
Align
Specifies an alignment through a drop-down list
Border
Sets the lineweight and color of the cell borders.
Lineweight
Sets lineweight through a drop-down list.
Color
Pick a border color from the drop-down list, or else choose Select color... to display the Color dialog box.
Cell Frame
Applies the border properties to specific lines that make up the cell frames.
Table Direction
Determines the direction in which the table grows when you add and remove rows.
Down
The title and header cells at the top, and the table grows downwards.
Up
The title and header cells at the bottom, and the table grows upwards.
Context Menu Options
New
Creates a new table style.
Delete
Deletes table style definitions from the drawing. The following table style definitions cannot be deleted:
  • Table styles in use
  • ‘Standard’ table style
Rename
Renames the select table style.
Select All
Selects all table style definitions.
Invert selection
Deselects the current selection and vice versa.
Set current
Sets the selected table style as current.
