BOM Settings dialog box
Configures part references (Part References) properties and set up default properties for parts lists, and data capture for the BOM.
  1. Component
  2. Parts List
  3. List of properties
  4. Add new
  5. Add pre-defined
  6. Restore defaults
Component
Contains a list of component properties that are visible in Part Reference. More properties can be selected by pressing the Ctrl / Shift key.
Above this list there are delete, move up and move down icons, which are available only when a row is selected or the selected row(s) can be moved up or down.
Visibility
Toggles the visibility of the property.
Property
Displays the name of a component property. This unique name is the one by which a BOM column is referred to in formulas.
Caption
Defines the column header to be displayed for this property in a BOM table or parts list.
Display prompt
Displays the chosen column header to be displayed for this property in a BOM table or parts list.
Data type
Defines the data type for the property (Numeric or Text)
Value
Defines the default value for the property.
Precision
Defines the precision for the property.
Parts List
Contains a list of Parts list properties that are visible in Parts Lists, by default.
In addition to Component properties settings, the following properties are available:
Caption Align
Defines the column header position in the cell.
Value Align
Defines the value position in the cell.
Width
Defines the width of the cell.
Add new
Adds new component properties as columns to BOM. Opens Add New Component Properties dialog box:
Add pre-defined
Adds new pre-defined component properties columns to BOM. Opens Add Pre-Defined Component Properties dialog box:
Restore defaults
Resets all settings to the default value for the current drafting standard.
