Export Civil Points dialog box
Opens via: CIVILPOINTEXPORT command
The Export Civil Points dialog box allows you to export the Civil Points to an external file.
- Format
- Include all point attributes
- File name
- Select points
- Format
- Allows you to select from the drop-down list a format for the exported file.Note: Press the three points from the right side to open the Manage Point File Formats dialog box to create a new file format.
- If checked, includes additional point attributes that are not defined in the selected format for export.
- File name
- Defines the path and file name.
- Select points
- Allows you to select Civil Points for export.
