Bricsys 24/7 Links migration to FormsThe new user interfaceProject folders migration to the new user interfaceWhere can I find offline Help for Bricsys 24/7?How to add or edit the metadata for existing documents by uploading a CSV filePermissions required when copying and moving an itemI don't see all applications in the app barI can't send notifications about a documentI don't see a specific user when sending a notificationHow do I delete a workflow?Is it possible to delete an annotation, a notification or a note?I want to stop receiving task notifications in my emailHow do I reassign a workflow task to another userWhy is the workflow task assigned to another user?Use OAuth Authentication for access to the Bricsys 24/7 APIUpdated LetsBuild configuration using OAuth2Parent topic: Knowledge base
