IFCIMPORTSETTINGSCONFIG system variable
IFC import settings configuration
Specifies the name of the IFC import settings configuration file.
BricsCAD only
| Type: |
String |
| Saved in: |
Registry |
| Default value: | "bim_ifc_settings.xml" |
BricsCAD only
| Type: |
String |
| Saved in: |
Registry |
