AMPARTREF command
Creates a Part Reference symbol and places it in the drawing area.
Icon:
Note: This command only works for drawings that contain mechanical entities. To set the environment for BricsCAD Mechanical drawings, see the Overview of 2D Mechanical Drawings commands article.
Method
The command is available only for drawings that contain mechanical entities.
Note: The Part Reference symbols is added to the AM_12 layer.
Select the object to attach a Part Reference symbol to it.
The Part reference dialog box opens.
Note:
- If you click an empty space in the drawing area, the program places an unattached Part Reference symbol (a Part Reference that is not attached to any geometry) at that position. The Part reference dialog box opens.
- In the Properties panel, you can edit the Part Reference symbol properties.
- When you double-click the part reference symbol, the Part reference dialog box opens.
Options within the command
- Block
- Applies a Part Reference to a Block Reference. The Part reference dialog box opens.
- Copy
- Copies a selected Part References to another place in the drawing area.
- Reference
- Duplicates the selected part reference and keeps them linked.
