CIVILDWGEXPORT command
Exports BricsCAD Civil entities as native CAD entities.
Icon:
Opens the Save Drawing As dialog box which allows you to export Civil entities as native CAD entities in a new drawing. You can flatten all the entities to zero elevation while keeping the annotation of spot elevation or contour labels with the correct representation. Also, you can convert GIS attributes to object data.
Options within the command
Flatten entities
Allows you to flatten all entities.
Yes
Flattens all the entities to zero elevation while keeping the annotation of spot elevation or contour labels in the correct representation.
No
Does not flatten the entities.
Convert GIS attributes to object data?
Allows you to convert GIS attributes to object data.
Yes
Converts GIS attributes to object data.
No
Does not convert GIS attributes to object data.
