Communicator for BricsCAD - Supported export file formats
Supported export file formats:
Windows
- 3D PDF: .pdf
- ACIS: .asab, .asat, .sab, .sat
- CATIA v4: .model
- CATIA v5: .CATPart, .CATProduct
- IGES: .iges, .igs
- STEP: .step, .stp
The following export protocols can be specified; AP203, AP214, AP242
- VDA-FS: .vda
- XCGM: .xcgm
- Parasolid: .xmt_bin, .xmt_txt, .x_b, .x_t
Export to Parasolid format is possible if:
- pskernel.dll is available in InterOp, e.g. in a folder accessible through PATH enviroment variable.
- P_SCHEMA environment variable points to the schema folder which can be found next to pskernel in its original installation. The folder name may slightly differ, e.g. in SolidWorks® 2018 it is
schema_18. - pskernel.dll version is earlier than the major version supported by InterOp, the EXPORTPARASOLIDFORMATVERSION system variable has to be set to a (lower) version that pskernel library supports.
Linux
- 3D PDF: .pdf
- CATIA v4: .model
- CATIA V5: CATProduct, .CATPart
- IGES: .iges, .igs
- STEP: .step, .stp
- VDA-FS: .vda
- XCGM: .xcgm
Mac
- CATIA v4: .model
- IGES: .iges, .igs
- STEP: .step, .stp
- VDA-FS: .vda
Note:
- When the EXPORTPRODUCTSTRUCTURE system variable is set, you can export a BricsCAD® assembly with mechanical components as a file with product structure.
- If the assembly contains hidden parts, you can decide how to process the export hidden parts by setting the EXPORTHIDDENPARTS system variable.
- All other related system variables which controls the export file types are listed in the Related variables.
