QUADMOUSEMODIFIER system variable
Quad mouse modifier
Determines the modifier key, if any, that needs to be held to launch the Quad with the Quad mouse button.
BricsCAD only
| Type: |
Short |
| Saved in: |
Preference |
| Range: |
0 to 3 |
| Default value: |
0 |
| Possible options: |
0: No modifiers are used 1: Use Ctrl as modifier 2: Use Alt as modifier 3. Use Shift as modifier |
