-BVSTATE command
Manages visibility states in a dynamic block definition via the Command line.
Disclaimer
Creating and editing dynamic block definitions under BEDIT in Experimental mode is an experimental feature which may not yet be stable, and could be removed in the future.
Use the MANAGEEXPERIMENTALFEATURES command (or the EXPERIMENTALMODE system variable) to turn on or off experimental features, then restart BricsCAD®.
The Experimental mode is turned off by default.
Sets the current visibility state, create new ones, or delete existing visibility states in a dynamic block definition via the Command line.
Options within the command
- New
- Adds a new visibility state to the dynamic block definition.
Enter the name of the new visibility state, then enter the entity visibility for the new state.
- Hide all
- Hides all the entities in the block definition for the new visibility state.
- Show all
- Shows all the entities in the block definition for the new visibility state.
- Current visibility
- Adds the new visibility state with the current visibility of the entities in the block definition.
- Set
- Sets an existing visibility state as current.
Enter a visibility state name from the list.
- Delete
- Deletes the named visibility state.
- Lists all visibility states saved in the dynamic block definition.
