BACTIONSET command
Specifies the selection set of entities for an action in a dynamic block definition.
Icon:
Disclaimer
Creating and editing dynamic block definitions under BEDIT in Experimental mode is an experimental feature which may not yet be stable, and could be removed in the future.
Use the MANAGEEXPERIMENTALFEATURES command (or the EXPERIMENTALMODE system variable) to turn on or off experimental features, then restart BricsCAD®.
The Experimental mode is turned off by default.
Important: In the event that you purchase BricsCAD® in the U.S. or for use in the U.S., this feature is neither available nor licensed to you. Please see EULA for more information.
Method
Select the action, then define a new selection set for the action or modify the existing one.
Options within the command
- New
- Defines a new selection set of entities on which the action is applied.
- Modify
- Specifies the entities to be added to or removed from the action's existing selection set.
- Add
- Adds the selected entities to the selection set.
- Remove
- Removes the selected entities from the selection set.
- CPoligon
- Defines the boundary area of an action (the entities modified by the action) by the specified polygon.
- Undo
- Undoes the last polyline segment and continue drawing from the previous point.
