BACTIONTOOL command
Adds an action to a parameter in a dynamic block definition.
Disclaimer
Creating and editing dynamic block definitions under BEDIT in Experimental mode is an experimental feature which may not yet be stable, and could be removed in the future.
Use the MANAGEEXPERIMENTALFEATURES command (or the EXPERIMENTALMODE system variable) to turn on or off experimental features, then restart BricsCAD®.
The Experimental mode is turned off by default.
Method
You can add an action to a parameter in a dynamic block definition. The action defines how the selection set in the block geometry moves or changes when the action is triggered in a dynamic block reference.
Enter the action type, select the parameter to which to add the action, specify the selection set and the action location.
Options within the command
- Array
- Adds an array action to a linear, polar, or XY parameter.
- Lookup
- Adds a lookup action to a lookup parameter.
- Flip
- Adds a flip action to a flip parameter.
- Move
- Adds a move action to a point, linear, polar, or XY parameter.
- Rotate
- Adds a rotate action to a rotate parameter.
- Scale
- Adds a scale action to a linear, polar, or XY parameter.
- sTretch
- Adds a stretch action to a point, linear, polar, or XY parameter.
- Polar stretch
- Adds a polar stretch action to a polar parameter.
