BVHIDE command
Hides selected entities for the current visibility state.
Icon:
Disclaimer
Creating and editing dynamic block definitions under BEDIT in Experimental mode is an experimental feature which may not yet be stable, and could be removed in the future.
Use the MANAGEEXPERIMENTALFEATURES command (or the EXPERIMENTALMODE system variable) to turn on or off experimental features, then restart BricsCAD®.
The Experimental mode is turned off by default.
Important: In the event that you purchase BricsCAD® in the U.S. or for use in the U.S., this feature is neither available nor licensed to you. Please see EULA for more information.
Method
Select entities in the dynamic block definition, then decide whether to hide them for the current visibility state or all visibility states.
Note: Use the BVMODE system variable to control how hidden entities are displayed in the Block Editor.
Options within the command
- Current visibility
- Hides the selected entities for the current visibility state.
- All visibility states
- Hides the selected entities for all visibility states.
